Aluminum GN1's/BG Off-Center Intake/76-Turbo
BAGN
God Bless America!!!
Selling for a customer who went the Stage II Route.
Champion Aluminum Heads
w/Full Race Port
Roller Rockers
Push Rods
Valve Covers w/Breathers
Cut For Reciever Grooves (1007)
ARP Head Bolts for Stage II Block
H.D. Valve Springs for Solid Roller Cam
Turbo LE-76Q w/3 bolt Exhaust Housing
Complete Bowling Green OFF-Center Intake w/
Plenum
83 lbj inj
Adj F.P. Reg
Race Port on Intake & Plenum
Solid Roller Lifters
ALL ITEMS ARE USED BUT IN GREAT SHAPE.
Heads & Turbo Made over 700 RWHP on our mustang dyno @ only 20 lbs of boost.
All work done by C.P.P.
Close to $7000 in parts. Will sell EVERYTHING for $4600. I want to sell as a package.
I sent you message on T6P about these. These sound like they will fit a stock 87 GN short block correct (ignoring the fact I might need to make it stronger to make 700 RWHP)? The included "ARP Head Bolts for Stage II Block" makes it sound like it might be set up for Stage II block and not a stock one.
Obviously these may also fit both. Is this the case? Please "educate" me..
D.
D.
These heads/Head Bolts will work with a stock block. You will just have extra head bolts left over. Intake is Off-Center so it will fit the stock block as well. Turbo has 3 bolt exhaust housing so it will bolt right on to a stock style exhaust manifold. Hope this helps,
CC
