T tes87gn Member Joined Jun 7, 2001 Apr 27, 2006 #1 What is the Torque Spec for ARP bolts and Aluminum GN1 Heads. I've tried to search and no real luck and gnttype.org isn't working right. Thanks
M MSA231V6 Member Joined Dec 31, 2004 Apr 27, 2006 #2 torque tes87gn said: What is the Torque Spec for ARP bolts and Aluminum GN1 Heads. I've tried to search and no real luck and gnttype.org isn't working right. Thanks Click to expand... The literature that came with my GN1s recommended 70-75 #/FT if I recall correctly. I chose to go a litle higher and have mine at 85 #/FT. No problems so far - the heads are sealed to the block with no coolant leaks, etc... MSA
