Hey the YELLING is tough love
Everytime I go to the track I get the butterflies.. and I go at least 2-3 times a month weather and car running
.. you need many passes to see whats what with the car. The McDonalds drive thru instant gratification doesnt apply, and tuning on some cars takes more work than others. So dont compare to what others are doing when figuring your car out.
You have a high 11 second car with some traction. To get it faster than than... you need to get data(record runs) and look/study your time slips and watch the cars progression down the track. Its not just ET/MPH.. the details 330/660/1000... are all part of the equation.
Get more seat time.. make your decisions.. and learn to observe what the motor and car is telling you.
As to the boost guage.. doesnt matter if its 5 lbs off. Its all a reference. If your crappy guage reads 20 PSI.. thats your reference. If you crank the rod in and it goes to 21.. then the guage is serving its purpose. Splitting atoms over one guage reads 26 and the other 22.. and the other 28.. doesnt affect the car getting a number. Whether you run 35 PSI or run 20 PSI.. you need to learn to tune what you have. And tuning doesnt mean play with an allen wrench on your fuel pressure regulator or crank the WG rod in. Tuning means making changes to injector duty cycle and advancing/retarding timing advance. Accomplished by changing parameters within the chip.
HTH :wink:
