GangsterMD
Turbo'd since '95
- Dec 29, 2007
So I melted #6 piston all to hell. I had post on here a while ago. Here's the thread. http://www.turbobuick.com/forums/engine-tech/264384-uh-oh-s-not-good-any-ideas.html The car has 100,000 miles on it and until the recent problem it seemed 100%. At this point I'm still not sure what caused the one piston and spark plug to melt. The others all are fine, the plugs were black, I wasn't lean on the 02's. However I was fighting KR readings in 3rd gear. I'm wondering if false knock could've played a part? At this point I haven't had the injectors checked to see if #6 injector failed? Any other thoughts on this would be appreciated. Now for the motor. I've been told to pull the piston and check the rod bearing? I was thinking of plastic guaging it? Should I guage the other rod bearings and the mains as well? Then if they are ok would I be nuts to just replace the piston? What maybe complicates things it that I was thinking of doing some upgrades now. I need to change the timing chain & gears (still stock), and I was thinking of a new turbo. I'm think it is the PTE GT6157 BB, I've read it will work with the stock converter. Then a stretched ic, and a bigger maf and translator. Last but not least doing something with the heads. Maybe champion irons? Or is port and pollish the stockers fine? Could this all work, and maybe put a girdle in it? I think I'm all over the board and would like some direction... Also if I do decide to pull the motor and replace all of the bearings etc. do I need to worry about who I get to do the machining? What I mean is I think I've read posts about that before - like these engines are maybe different than the average 350 rebuild? As far as goals go, I'd like it to be capable of running low 11's?
