In addition to my starting problem, http://www.turbobuick.com/forums/showthread.php?s=&threadid=45579
I also have a battery drain that seems to be pretty bad. Today I hooked a voltmeter between the positive terminal on the battery and the positive cable with the key off to see what was draining the battery. The first thing I noticed is that the drain doesn't appear to be constant. The voltage would be at 12.75 volts, then drop to about 12.5 or 12.3, then go back up. I pulled every fuse, and there was no change. I even pulled the two battery leads off the fuse box with no change. All this with the door open...so when I closed the door the voltage starts dropping and gets down to 12.2 volts. I am thinking that the factory security system is messed up and causing this problem. Is there a way to disconnect power to the security system and see if the drain goes away? Could this also be the source of my starting problem?
An explanation of how the security system is supposed to work would be helpful to me, also. This is a theft recovery car so chances are the system has been tampered with.
Thanks in advance,
Jeff
Thanks in advance,
Jeff
