So before I install this new hydraulic flat tappet cam (comp brand), they suggest Nitriding and/ or removing the inner damper spring to properly break it in.
My questions are these;
Does everyone run just the outer spring for break in? and does anyone get this nitriding done?
This engine has had the LT1 spring upgrade,probably when the cam was changed 5000 -8000 miles ago. But it wiped the #4 exhaust lobe and was starting to wipe 2 other lobes.
Can I just follow the break-in procedure for new cam and lifters or do I need to take the damper springs out too?
What about nitriding? Where can I get that done and what does something like that cost?
