Mar 22, 2012 #1 G G NASTY Active Member Joined Jun 19, 2008 Messages 1,128 Do I still need to find tdc for a cam sensor that is already installed? I moved it a bit to see if it would solve me no start problem now I want to make sure it's set right. I have the caspers tool.
Mar 22, 2012 #2 T turboclam Well-Known Member Joined Sep 30, 2003 Messages 2,109 I think you set the cam sensor at 25 degrees after TDC?
