Hot Air Beast
Hot Air Lover
- Mar 10, 2007
After driving for ten minutes and being parked for 30, my 1984 GN would not start. After a few tries, it started and drove fine for 10 minutes to home. Next morning, would not start again. Pulled code 15, "abnormally low coolant temperature". This code causes the fuel to dump. I changed the sensor and the car started right up. I thought the problem was solved. An hour later I started it again and the idiot light on the dash came on and stayed on (overheat light).
Could this be a bad sensor out of the box, or should I be looking for something else? The only wire that was moved was the connection to the sensor.
