Car has to be at about 226 degrees water temps. for it to stay on after the key is off.
A quick test of that useless system is to put a ground on the dark green with yellow striped wire on the big fan delay relay with the car idling.
Turn the key off and it should run on the timer, don't forget to remove the ground wire when done testing.
