OK, my cooling fan is not working. Went to Vortex Buicks and did the troubleshooting. Found that the fusible link was bad. So I replaced it and it went bad again. So maybe I had the wrong size and replaced it again with 16g, which should be correct. When tested by grounding out the coolant switch connector, the fan runs but when I take it for a ride and get it to temp, the fusible link popped.
Just to answer the upcoming questions;
I replaced the relays and removed the relay that allows the fan to run after the car is shut off
I checked the ground at the fan... seems good
I took the high/low resistor out of line
When I put 12v to fan she runs
No power at the red wire at the relay (because link popped again)
Either there is a short, if so looking for suggestions on where it could be, or the fan draws too much at startup. Or, looking for solutions here...
