turbotaone
- Jan 22, 2003
After hearing that the silicone used on the steel shim headgaskets kits can plug the small water passages in the gaskets, I got worried because I had just installed a set of the steel shims on my car last fall.So while the engine and tranny are out of the car I figured that I might as well pull the heads and take a look. When I pulled the heads off today SURE ENOUGH, there was silicone plugging two of the holes completely shut and the other two only had a pin hole of light shining through them. Needless to say I'm no longer a big fan of the steel shim headgaskets,which by the way I had installed exactly as the instructions stated. My question now is which brand of the factory style headgaskets are you guys using? I've always liked Felpro products and was thinking of going with their headgaskets. Let me hear some opinions please?
James
James
