C
coach
Guest
I just finished my install. I got the "armed" and "spray" light and no "low". I put methanol in tank and turned key again, still the same. I started the car and it runs fine, also got new TT chip for ALKY and 93. I push test and car stumbles like it says in directions. I can hear that pump is running. It says in directions, about 30 psi will be applied, I reached into car with a long wrench and pushed test again, pump gauge flies to about 100 psi or better. I tried adjusting the "start" and "max" dials to get light to go out, but it won't. I also noticed when I turn the start dial all the way off, nothing happens, when I turn the max dial off, the pump comes on. All this time, "spray" light is on.
What gives??? Any suggestions will be tried.
Coach
Coach
