captndave737
- Feb 14, 2006
You basically need 2 VSS’s to make everything work. The 3 wire one for the speedo is an 8 or 16 pulse VSS. One wire is power, one ground and one is signal. You need a 2 pulse, 2 wire VSS if you want the cruise control and TCC to work.I checked the vdo setup in my car and the difference is the vss sender is 2 wires and 3 wires.
I have the red vss wire butted to the green and red wire on my buffer.
The new dash is 3 wire sender.
