If you have the mixture screws in the whole way, you are drawing air in somewhere you aren't supposed to, think vacuum leak. Intake gasket, brake booster, p.c.v., vacuum advance diaphragm, vacuum hose....If you can't find it, you may have internal carb cracks or air going around the throttle shaft. Did you match up your gaskets (overlay and hold new and old gaskets up to lighy, EVERY hole needs to match perfectly)? Sometimes in the aftermarket the gaskets aren't made properly and the ports are either blocked or allowed to vent to atmosphere. As already discussed, timing and dwell will do the same thing. Did your damper pulley slip? Take your vacuum gauge on a manifold vacuum source. Base vacuum should be 15+, advance distributor to max. available vacuum. Should be 20+, if not, you have other problems. If it is 20+, back distributor 2" vacuum and timing wll be very close. Hope this helps. Just double checked your post, if it was flooding, either the needle and seat were dirty or worn, the float was heavy (brass: had a hole in it, or nitrophyl black absorbed fuel) or the choke wasn't coming off. Also, did you soak the carb in solvent? That's were your throttle shaft problems start. It will wear from years of use but was blocked by years of crud you just cleaned off.
