TIMINATOR
- Jan 26, 2020
My 87 Turbo Coupe Ltd. came with a 7 1/2" 2.41 geared rear end, and I assume the last owner had a good, or nefarious reason for changing it. I replaced it with a bolt in 9", 31 spline axles and good posi, and 11"x 2 1/4" brakes instead of the 9 1/2 x 2 stockers. I figure I can stall it higher on the footbrake launch, not a bad thing, and it came without brakes anyway. I assume others have done this, so my question mainly is will this upset the brake balance enough to cause problems? Will I need a proportioning valve? Or mebbie bigger disks on the front? I am not the guy that puts huge brakes on everything, I don't see the need. My other GNs stopped just fine with the bigger tires I had on them and stock brakes, but stalling it up pushed thru the stock brakes easily.
I never had any problems with my 1968 454 8-71 blown Nova, that originally came with an anemic 6 cyl. and tiny front drums. I had the same rear brakes on the 9" that I put in it.
I am just finishing up the new motor, so I figure if I need something, I would order it now.
The Nova ran 9.60s @ 141, but I only expect mid 10s with the Buick, and I'm not gonna do a roll bar, just stiffen the frame.
It, like the Nova, is just a street car, but both of the dragstrips are now gone.
TIMINATOR
P.S. it ran good, but was kind of lazy under 35 mph or so....
TIMINATOR
