SignUp Now!Bogie1, My 87 turbo t has stock long block with valve springs, big neck stock int, ta49 with blue tops, thd, blah. On slicks in 85* weather, the car ran 7.64 at 91mph with 22psi , 5psi launch, 1.73 60'. Red stripe 2800. I have 3 exhaust housings for this turbo- stocker, pte .63, pte .85. the first two mentioned work fine. The 85 is very "laggy" with my combo.Originally posted by bogie1
Tks DR.B
Have you had the chance to take your combo to the track yet?
Was wondering what kind of times to expect if I stay with the TA49 and .63 housing.
60ft?
1/8 or 1/4 mile?
Shane, I think your combo will be more forgiving than mine with the larger housing . pte .85 inlet is 2.5" wide, the pte .63 inlet is 2.25", stocker inlet and p-header outlet is about 2 1/8". Im not familiar with garretts .82 . I think you can see why my 2800 isnt quite enough to drive around on. 5lb launch, no problems with any.Originally posted by snatchSS454
hello,
I am in no way trying to hyjack your thread, but it has really caught my attention since this is gonna pretty much be my set up.
Turbo-Garrett T3/T04E (60/.82) (#466159-5008S)
T3/T04E - Non Ball Bearing Center Section, .82 A/R T3 Turbine Housing, 76 Trim Turbine (Stage III), .60 A/R T04E Compressor Housing, 60 Trim Compressor Wheel. 4 Bolt Discharge Flange
Ported Heads/Intakes-Flow 228 intake 194 exh
Edge 3000 stall-carbon fiber internals, with 97% eff. and somewhere between 2.5-2.6 Torque Output
3.42 rear gear ratio and posi in my 2000 camaro 3.8L. Some of you are saying that this setup will be very laggy. Are you refering to a stock engine setup? Do you think with my flow numbers that I will have a major lag issue?
Thanks,
Shane
