Will,
What is your goal?
Things to know:
75hp shot will increase boost about 2psi, on a stock gn it will drop 1/4 around a full second.
125hp shot will increase boost about 4psi, on a stock gn it will drop 1/4 around 1.5 - 2 seconds.
Precautions I would do:
1. knock gage- knock is bad on a gn but VERY bad on a nitrous gn.
2. fuel pressure gauge- you need to make sure your fuel pump is keeping up with the demand or you will get knock which will kill you motor.
3. 75hp shot you need stock timing chip ( no strip chip unless it's a nitrous chip). With 150 you need nitrous chip or stock timing chip and race gas.
4. adjust boost for the jump in psi for selected nitous hp level.
5. with 75hp uses stock spark plugs or one colder. with 150 use 2 colder.
6. make sure engine is in good tune- new plugs, spring cleaning (new fuel filter), and tranny has clean fluid and filter as it will take alot of torque.
7. When racing you will probably need to hit the nitrous after you start rolling if not using slicks as you proably lose traction from a dead stop.
8. Using NOS systems I have notice they fuel jet is on the fat side so if you get the car tuned in you will find more hp in leaning out the gas jet. On one gn the chip was on the rich side and once the nitrous was added we started getting a back fire on intake. At first we thought it was a leaning problem so we added more fuel, no help. We call NOS and they thought it was leaning and added more fuel. Ended up being to rich, we leaned it out and wow. She ran great. That was back in 87 before all the great monitor tools we have now. In short NOS system tends to be on the rich side. So you have good fuel pressure with factory jet and you get intake pops you are probable rich not lean.
I have been partial to NOS systems, they have been very reliable. We have a guy here in New Mexico that has lightened his car as much as possible and has a stock long block, stock turbo, stock tranny, and all with 130,000 miles with my chip and a 75hp chip that runs 11.4's.
Hope that helps
Chuck
