the reds (redregalT) turbo luber a remote filter plumbed inline with the turbo supply . it replaces the stock steel line from the brass block at the side of the timing cover to the turbo with a 4AN (i think its 4an , may be only 3AN ) braided line to the filter block (which gets mounted to the front of the turbo sheild and looks stupid there IMHO) then to the turbo with another braided line.
the PTE mounts at the oilpump using a spin on adapter (can use with or without the oil cooler adapter but i run mine without the oil cooler adapter ) and the oil flows from that adapter through 1/2" hose to the remote mounted filter (mounted behind headlamps on rad support ) , after passing through the filter it returns to the engine through a 1/2" hose , and off the filter block (on the filtered side ) is a seperate 4AN braided line that feeds the turbo.
the filter is easy to get to and the block has the std threads like when you run the biggie filter adapter which allows for running a large filter , and the filter sits vertical so it doesnt drain back so no oil starvation on startup
