Anybody replace rollers on window regulator??
PaulRV6
It looks like the rollers are worn out on my window crank assembly, has anyone replaced these? I need to know what it takes to get them off/on? Do they just pound on the metal post or do they press on? Thanks
paul
The replacement rollers from GM(part number 22049666) come with a threaded stud that replaces the pressed on/riveted original. Just drill out the old stud.
Eric Fisher
Turbofish38, you must have replaced these before? So it must be the rollers do not come off of the stud, it is an assembly?
Mine seem to wobble allot on the back side unless they are suppose to do that, any idea?
To get the regulator off, do I have to drill out some rivets? It sure looks like it. Thanks for the help.
paul
Well no I have never had to replace one. I work at a GM dealer and we sell these a lot for S-10's that use the same roller. I've never really noticed how sloppy a stock one really is so it might be normal. Usually they break or pull off the stud. Eric
Eric, Thank you. Any idea oh how much they cost?
Anyone else ever deal with these rollers or the window regulator that could offer some help.
paul
Part number 22049666-GM suggested retail price is $15.05 apiece. BTW this is for a power window, post back if you have manual. Eric
Eric, I was going to mention I have manual windows and the P/N you mentioned is for electric windows. I checked with the dealer today and he said that GM does not sell these rollers separtely, it has to be bought with the regulator/balance beam assembly.
If you know otherwise please let me know. Thanks man.
paul
paul
