Jan Larsson
- Nov 22, 2001
I'm replacing my front hard brake lines as my original ones are rusted and will not pass this years inspection coming up in July ...
Anyway I bought the correct stainless set from Fine Lines Inc a couple of years back and been putting it off for some time, started the other day and got the driver side done without any major problems but the passanger side does not look easy to do as the line runs accross the engine cross member (in front of the engine mounts) and then up under the downpipe down and around the control arm ....
As the lines are pre bent identical to the original ones it will be a pain to route them in there as there is not enough space at all looks like ..... getting the old one out is not that hard as I can cut it if I have to but getting the new one in there might be a problem.
Anyone done this with the engine in place (if I took out the engine it would be a no brainer of course )
Otherwise the lines are identical and looks great, all stainless. Anyone need some I can post more detailed info what to order.
