In my quest to approach a way to "re-charge" an accumulator ball..... I was wondering exactly what was inside one? I have a bad one.... but it is my only bad one.... and if I cut it open..... I won't be able to attempt to recharge it. I was thinking about drilling a small hole through the bolt head on the accumulator ball and threading it to accept a fitting that could be used to charge the inside with nitrogen. This will work fine.. if there is a diaphram inside..... but if it is a closed bladder..... filled with nitrogen... it likely isn't going to work.
I have convinced myself after some thought... that it is probably a bladder that got put in there....but I am not sure..... If it were a diaphram.... my idea might have some merit.......
Any thoughts?
Any thoughts?
