1KWIKSIX
- Sep 29, 2007
Recently installed my new Precision DBB 5857 (.63 A/R) with S ported shroud. I've got a 3" internally gated DP.
My initial set up was with an adjustable HD wastegate actuator & RJC Boost Controller / Bleeder Valve.
Waste gate rod had 1/8" tension & RJC Valve fully open.
Because I've still got my stock D5 installed, wanted to try the RJC boost controler / bleeder valve to help spooling (cause I heard it could be a bit lazy with a D5).....I do have a PTC 10" L/UP 2800 to install once I get the boosting issue under control.
I ran into overboosting problems and had to take my foot off the gas at around 23-24 lbs boost (and rising fast).
Boy these turbos spool quickly.
Since I am not spraying alky....just 94 octane pump gas.....I decided to change over to the standard actuator.
Same results with overboosting. Maybe it's just a spike, but I've had to back off immediately once I see the needle race past 22lbs boost.
I have not matched the WG hole to the puck or ported / radiused the inside edge yet. Didn't think that it would be a problem on such a small turbo.
I'm going to be removing the RJC Boost Controller Valve and try a run using the factory's stock electronic waste gate control valve instead. Not sure if this will make a difference or not.
Just for the record.....have been running 20 lbs boost with no knock on my set up for years, even gone as high as 22lbs boost for a period of time with no KR.
If anyone can comment on their experiences with this turbo and boost issues...please chime in.
Patrick.....are you out there?
thanks,
dave
thanks,
dave
