Hey guys, need some help,
The guy that sold me the Spreedpro setup had clipped the labels off two sets of wiring, one is my crank trigger and the other is my sync, so i dont know which is which ... both are red, black and ground to engine block. Need to know which set of wires is my crank to goto magnetic pickup to fire at each cylinder vs which is my sync to know when 1st cyl in coming up.
Also, I'm only using the dos c-com version, the floppy I have with the ccom WP is messed up because when I run the setup.exe file it says disk error. anyone know where I can download a copy of this program ?
One more question, can ccom read from an electronic speed sensor to retard timing on my lauch in 1-2 gears based on speed ? Is there a trigger that I can use to retard timing at launch (and specific how much timing to pull) ... not sure if NOS connector can be used as I've converted to sequential.
And lastly, how do you guys use the remote logger capability, anyone ever use that ?
thanks a lot,
Greg
thanks a lot,
Greg
