Got my car running yesterday, but IAC doesnt work. I got a 180 target, idle speed is too low, and when I pull out the IAC, its shut (fuly extended)
My only thoughts right now are I am missing a ground somewhere as it worked fine before. Also, are the WB O2's grounds tied into that ground anywhere? My target/actual are ok (13.8) but my old zirconia O2 which I use for my O2 gauge (I use it because I know where it used to read with the stock ECM so I can get close) reads pig rich.
So I think I may have a bad ground out there somewhere. I'll bring my IAC checker home tomorrow to check the circuit, but I tried 2 IAC's and both did the same thing.
Oh, one more thing, anyone ever see erratic info on your data tables? I went to a larger cam so I wanted to pull out some MAP AE, so I did, ok, this is good, I shut it off to see how it starts and every time vac changes I get a gulp of black smoke, I go to the table to recheck and where I edited it MAXED at whatever, 5mS? I pull it back down and close the table and it stuck. So I wonder if its a bad thing to shut the engine off with the table in question in view.... like somehow a spike accidentally edited it...either that or that further supports a bad ground as maybe the digital comm ground is tied in there too?
Any ideas?
Any ideas?
