Re: Hey Bruce...
Originally posted by captrob
Did you leave the screen in on the blow through setup? Think I read where the screen straightens out the air flow like a diffuser. Am I correct?
They even the air flow out across the entire meter's sensing area.
There is an advantage to leaving it in for a smoother idle, it's not going to make it glass smooth, but it is a little better as far as *jitter*. It also seems to help in really cold weather, ie 20dF.
My current setup is with the screen, and no vane.
You can over do it, and get too large of cross sectional area, and there is a point where the sensor can be made to screw up but it takes some machine work on the housing, to do that. There are perferred angles for the entry, and exit from the sensor's area.
The best combination I've had to date is the 3.5 sensor in the 3" housing, vaneless, with screen, blow thru. But, that's for my combination.
If you have to go screenless, and vaneless, then you should use a WB to make sure the calibration is right. The Buick engine is a miracle of forgivingness, and you can run it with a really poor cal., and it will seem OK. Just that you'll be replacing headgaskets, and rod bearings alot more often then necessary.
