anyone using Presion Turbo remote oil kit ..i got ?
Fast4Ward
don't even ask how many times i've had it off for various engine stuff but now im confusing myself on the outs and ins.
here's the brain fart...the housing at the engine is labeled in and out
the remote filter housing is labeled in and out.
am i following in to in and out to out or am i going from out at engine to in on the remote housing and out at remote and in on engineo_O
One way to check this is that: oil enters the filter around the outer edge. Then goes back to the engine feeds via the center hole (the threaded opening). Can check each piece to see what is what.
The IN on the remote filter housing comes from the outer edge of the pump adapter. With the OUT of the remote filter housing going to the center of the pump adapter. And the turbo oil feed is also from the remote filter adapter OUT.
There is a good photo of it here:
http://www.gmhightechperformance.com/tech/0309htp_precision_turbo_install/photo_05.html
RemoveBeforeFlight
I happen to the instructions here on my desk along with their plumbing diagram
FWIW the newer models the hoses will only go on one way
