Silverfox: I already nabbed a set from an 87 cutlass. They charged me 3.99 each. There is at least one more set there, if you needed some (off of 78s). I did save the bolts, but the ones at the center cross member section had the tops ground down I guess from hitting stuff. Made them a bear to get off. I have a set of bolts that are the same thread that I'll use to replace these.
