I also would not say you wasted your money, but the ARP rod bolts are not needed. Also when assembling the heads to the block, use a teflon sealer on the threads and some moly lube on both the top and bottom of the washer under the head of the bolt. This will ensure a proper torque when performing your toque sequence.
