- Jun 18, 2001
I have most of the parts to do a NOS build on a stock Turbo Buick V6 and I would like to sell it all as a package. These parts are all new NOS GM and have not been out of the packages $1200 plus shipping
Crankshaft
Camshaft and Lifters
Timing Set
Rod and Main bearings
RIng set
Also included are: GM Headgaskets, oil pan gasket and valve cover gaskets.
Not included but I also have:
New NOS pretty much every sensor, Cam Sensor, crank sensor, CTS, Oil Pressure sending unit, temp light sending unit, MAF sensor, Upper manifold plenum, Intercooler fan
Used parts, I have everything EXCEPT a stock 109 block pistons and rods all brackets pullies pieces parts etc.
I do have a 109 short block for sale, billet center caps, studs, 3.810 bore, DSS Pistons, GN1 perf Rods, P1 rod bolts, 4340 3.625 crankshaft, 212/206 Weber Billet roller camshaft with Rollmaster timing set and stack up. $6500 done and assembled. It is currently at machine shop getting caps installed, will sell as is without assembly.
Crankshaft
Timing Set
RIng set
