Assorted Parts, Still Cleaning Out Garage
TURBOGTA1
Life is Sweet !!!
HIGH PERFORMANCE PUSH RODS,WITH LESS THAN 2K MILES,
PRIME ONE- 8.700 .065, $40
36MM FRONT HOLLOW SWAYBAR OUT OF IROC-Z, $65
I HAVE A BRACE I THINK IT IS OLD ATR,BUT NOT SURE,IT GOES IN PLACE UNDER DRIVESHAFT,BY TAIL OF TRANS.REPLACES THE STOCK BRACE,(stronger) $20
GUAGE HOLDER THAT MOUNTS IN CENTER CONSOLE UNDER
RADIO AND HOLDS 4 GUAGES,IT IS BLACK IN COLOR,$30
USED ELECTRIC COOLANT TEMP. GUAGE,NO SENDOR,$20
USED VDO 30PSI BOOST GUAGE WITH ALL ACCESORIES TO INSTALL, $20
NEW GN LICENSE PLATE,$10
NEW GM WASHER & COOLANT TANKS,$40 FOR BOTH
CLEAN USED FENDER EMBLEMS,GN & INTERCOOLED,FOR GN
3 BRAND NEW GM CENTERCAPS FOR GN. $60
GNX STYLE DASH WITH NO GUAGES OR WIRING,PROJECT STARTED,NEVER FINISHED. NEEDS GUAGES AND TO BE WIRED UP!! COMES WITH OUTER DASH PANEL. MAKE OFFER!!!
NEW GM OIL O'RING FOR OIL FILTER HOUSING. $5
NEW GM S-SHAPED HEATER HOSE,FROM BACK OF WATER PUMP TO INTAKE.$20
BRAND NEW GM RING AND PINION GEAR,3.23 RATIO FOR CAMARO/TRANS AM 7.5 REAR. $100
NEW OIL FEED LINE FOR TURBO, $20
E-MAIL- TURBOGTA@AOL.COM
Also For Sale Is A Brand New Aluminum Rear End Cover That Has Cooling Fins And Gn Logo On It. Comes With New Gasket And Hardware. $70
