I guess I'm just curious how far the pump will continue to increase it's output, when referenced from the map sensor.
Reason I ask is... at 18psi, I have the dial turned all the way up and I'm seeing O2's in the 790-800 range... that's in the top of 3rd gear WOT.
If I turn up the boost, will the pump increase along with it and compensate due to the map sensor ? or does the pump only run up to a certain point and level-off ? (requiring a 2nd nozzle)
Sorry if this is a stupid question... I've been away from these cars for almost 2 years now. I'm a little fuzzy on some of the finer details.
