ATR Strip Chip for stock injectors
turbo89
ATR HP138A Strip chip for stock injectors - $25 shipped
Ran 12.8x @ 105 on stock GN
I have a bone stock GN with the original eprom chip. Would this be a good stock replacement for the old oem chip? I've read that just having an updated chip compared to old can improve several things including rough stock idle? If that's the case I'll take it!
To Answer honestly the idle with the ATR chip was good .. this is a Strip Chip .. meaning its setup for HIGH BOOST and HIGH Timing ... its not a daily driver chip ... it requires higher octane... its a chip meant for the race track or if you run around set on KILL all the time and have the octane to support it.
TTT
Same chip in a TTA has run 12.8x on stock tires with no other parts added.. just this chip and race fuel .. simple cheap 12 second bolt on
