ATTENTION MR.GRUMPY brakes
SNOWBIRD
as your car has dipped into the nines ,,,I would like to know what type of braking system do you have on your car and if it is stock what would you do do for a up grade and still keep the 15 in wheels ....thanks
Hydroboost Conversion
The Hydroboost Can Hold The Car, Some Guys Have Reported Here, Up To 22 Lbs Of Boost On The Line. It Also Can Set That Line Lock Real Hard. It Can Put Out Up To 2000psi At Idle Pump Speed. More If You Like. It Also Cuts Rotor Heat, Because The Car Stops In Less Distance. Using Baer (corvette) Brakes Requires 17" Wheels, And Still Needs Higher Pressure Than Stock To Energize Them.
all stock except for the bigger wheel cly's in the rear .. oh put SS lines in place of the stock "rubber" one's :cool:
