87gnblackdemon
Don't Be Redikulas!!
- May 24, 2001
I am calling out to you all since you have always had great answers and suggestions in the past. I (me and the old man) are beginning to build a trunk setup for my GN, much like AudioWizards except my subs will point to the back. I am wondering what it is you(AudioWizard) used to mount your amps to?, the white material. I was thinking of using some sort of tub to lay them it, but haven't found one yet. And are you or anyone else using fans in their setup?, and how do you go about hiding them and powering them? I have looked for help with box dimensions before, so this time I used the formulas and this is what I've come up with 44LX13HX15D= 2.47 or 2.5 cuft per chamber outside, and inside would come to 2.08 or 2.1 cuft, I subtracted 1 inch from each measurement for the inside measurement since I'm using .5 inch MDF, is .5 inch MDF ok? . The box recommendations are 2.0 per chamber or bigger, so as close as I can get is good enough for me. I did not subtract cone or sub displacement since I've had a hard enough time getting a box big enough to fit without coming out to far and hitting spare, and these measurements are the best I've been able to do. We are starting the box at the back of the 6x9 magnets. Anything else you think I should know while doing this project, would be appreciated. Thank-You
