TurboRussty
- Oct 15, 2002
well i installed the following new speed pro double roller timing chain, deleted the timing chain dampner, but in a new cam button bearing (updated type not plastic one),new water pump, 160 t-stat, new rad hoses, new gaskets everywhere, new oil pan gasket, new rod bearings (standard size clevite 77) i had cleaned up the crank just slightly and when i mean slightly i mean slightly with a piece of material that was given to me at a machine shop like a sand paper on a strip.
the reason i had changed the rod bearings was due to a very low noise coming from the sides of the car that you could only hear from the sides and not from the front of the car. it almost sounded like a lifter but a little denser in sound and comiong from the bottom of the car from the oil pan.
well the car previuosly was making a noise everytime on start-up it sounded like a very fast rattle noise as the engine starts up then revs down and goes away qucikly after that. you only hear the sound for approx. 2-3 secs. very fast then the noise from the bottom of the car comes out after a little while of driving you do not hear anything if thew car is cruising at about -20 lbs of vacum and then when i bring it on up to -5 vac or 0 on the guage then you can hear the TACK noise a little more but still very low but increasing with the amount of throttle you give once it boost then you do not hear it anymore. and when you are doing 70-75 forget about it you do not hear anything at all and the car runs,revs and drives 100% hard as a$$..
well after getting everything done myself and torquing everyting to specs the car started up with out any of the above for about 10 mins of driving, i then turned off the car filled up with some gas and then when i went to start it up the car did it again that brief rattle noise and then it went away but the TACK noise had come back.
what on on gods green earth is my damn problem.......
anybody somebody......
