Well i decided to go a bit of a different direction because i am on a very tight budget and i absolutely hate paying double shipping charges when i can get it all in one place!
I took the idea Jsta6 had and did some investigating. Perma cool shows a 300 degree working temp and a 250 psi working pressure on their fittings with the 1/2" hose so i felt pretty safe running 70-80psi cold oil pressure through it. I found everything I needed at Jegs.
B&M SuperCooler 70273
Perma Cool 1/2" barbed fittings 2 pair 15156
Perma Cool 1/2" angled fittings 1 pair 15158
Hose and fitting assembly kit, comes with thread sealant and hose lube 28010
Jegs Oil cooler hose 1/2" x 12feet 51720
Cooler mounting kit 53500
Even though the tech at perma cool said i shouldnt need them, i think im going to use some hose clamps just to feel safer. But the whole project is getting shipped to me in Montana for under $140!
Im doing the fbody swap, with a trans cooler inline after the radiator, and installing dual 12" spal fans. I decided to upsize to the dual 12" since I am keeping AC and running a precision front mount. I figure by the time the air gets through the front mount, oil and trans coolers, ac condenser, and radiator its going to be moving fairly slow so i needed all the pulling power i could get! Not to mention its only $65 more for the 12s. Caspers said they would modify the harness for free since the dual 12s use a more heavy duty sealed plug.
Once everything is put together I will post some operating temps.
Its going to be a few weeks since i have to do a cam swap at the same time.
