Back-up lights busted
TRBON8R
My backup lights aren't working. Probably a fuse gone bad. Anyone know what circuit the backup lights are on?
Check the reverse light switch above your ankles on the steering column. Make sure it's adjusted properly, it may come on between gears. Have a friend watch while you shift from park down to 1st. The switch is white and on the top side of the column.
Backup lights are on the same fuse as turn signals. 3rd one up on the left side of panel - 20 amp. If you have turn signals, it's probably the switch.
Prolly the switch. I have to push my shifter toward park to get them to come on.
Thanks much for the help. I've got turn signals so it must be the switch. Thanks again.
