Reverse lights...strange issue
BDG71
Help guys...when I put my Buick in reverse, the reverse lights flash...but do not stay on. What would cause this strange issue??
Anybody have a solution??
Gear selector switch base of steering column.
Thanks Salvage...these diagrams are great. Can you simply explain, once I'm under there, what I have to do.
Which way do I turn the "Gear Selector Switch"? Is that the white half moon looking switch?
That's the switch, I have no idea which way it has to be moved it's usually a two person job.
Put the car in reverse(car doesn’t need to be running) parking brake on just in case, do the dance between the shifter handle & the switch.
You’ll know when ya got it right. The reverse lights will come on when needed & go out when needed(with the correct shifter handle position).
Two people do make the job a bit easier though.
Lol...what do mean "do the dance"? Are tools needed? What exactly am I adjusting?
Please help!
Please help!
You have to move the shifter to the correct spot & adjust the switch accordingly.
Once you try you’ll see.
