Headlights will not wok
Hey guys my headlights do not work on my 85 GN. I have parking lights but no low or high beams? Any advice where to start? TIA
Mike
not assuming anything ...if you have hotwired lamps like used for h4 bulbs then check for power to hotwire relays from battery
pull dash bezel and remove headlamp/ parking lamp switch and check C connector for power
if no its fusible link at starter
is there power to the headlamp plugs, grounds connected at fenders?
check the column mounted hi/lo dimmer switch (on left side of column above brake pedal)
pull the connector and check for power at C (turn headlight switch on ) , if it has power replace the hi/lo dimmer
note just looked at diagram and the headlight dimmer switch designation or diagram for it is wrong
it shows in elec diagram C is 12v and A+B are out to lamps ..
in connector terminal diagram it shows A-D terminals but there are only three terminals , C is power in D + B are out ... tan to lows , lt grn to highs there is no wire at A terminal
