th200-4r reverse on position 1 and no foward speed
Heat treated ain't the same as billet. And your symptoms point that way. And even billet could break theoretically.
Those drums(fwd and direct) can be actuated with air on the bench while disassembled. The band can be actuated through the exhaust port on the pan rail while assembled. While actuated you shouldn't be able to turn the out put shaft.
The tests you are telling me about were done and everything worked.
My problem was already present before I replaced the forward drum. I replaced it to be sure this part was good, and I checked the air flow before installation.
I saw on the Gbody forum that there are color hydraulic diagrams for all gear positions that allow you to know which parts are activated depending on the selected gear.
Do you know where I can get them?
Is this a special technical guide?
This book has pictograms of things you describe. I"ll have to dig mine up and see what I can find. Some times copies of this book come up on ebay.
I'm going to look on eBay, it could help me, I think, to better understand the oil circulation in reverse and lo
Sorry, I thought I'd answered you.
This part was replaced, and I haven't noticed any difference.
If anyone has the THM200-4R operating principle, I'm interested. Otherwise, I'll end up buying a Stage 1 gearbox, but frankly, I'll regret it.
i,
I disassembled the valve body to check that all the pistons were properly installed. It's fine. I realized that I had installed the manual valve with the hole on the gearbox body side (ATSG doesn't indicate the direction, and I didn't take a photo).
New test, still no speed in all positions despite changing the engine speed to reverse, but I no longer have reverse in 1st gear.
