Anyone done any measuring of backpressure on their turbos? I'm running an PTE88 four bolt on a stage II headed 274 and was wanting to compare. Don't have much choice as far as exhaust housings, but was wondering if going to a 4 inch downpipe from the 3.5 could affect it any. My preliminary readings seem to be higher than Harry told me to expect, but we haven't got to play with it much yet. Had a little trouble getting the check valve to seal to get a true peak reading, but it looked like 30 PSI of backpressure on a 20 PSI boost run. Little hard to remember to look at the gauge at 115+ 1/8 mile trap speeds. Just trying to track down my next hurdle to making more HP.
Greg Kring
Arlington, Texas
150 MPH and street driven
P.S.: Excessive spring pressure pointed me towards checking back pressure. I am having to run upwards of 700 PSI over the nose to keep from floating the valves at 7K rpm. Yes the motor still has titanium valves and retainers, so I don't know where else to go to ease the spring pressure. Stage II roller cams with even fire lobes and an odd fire nose with roller cam bearings aren't exactly stocking items and I would hate to tear one up with the crazy spring pressure and street miles.
Greg Kring
Arlington, Texas
