well i started my disassemble of motor and found the number 3 exhaust lobe worn down as well as number 5 it is way lower and round than the others. this is a 204/214. does this look worn to you. it is ticking loud and setting knock sensor off at idle and has the sputtering problem also. the pushrod was slightly bent
