I'm new to this forum and the wealth of information here is amazing! I have a turbo tweak street chip version 5.6. I'm running 100 octane. The car (tta) is stock with the exception of the chip. I just purchased a scanmaster and am trying to fix the rough idle. The car would idle really rough when cold. I needed to keep my foot on the gas to keep it running until it warmed up. The IAC was at 175. I adjusted it down to +/- 40. However after I drive the car to warm it up and then re-start it the number starts at 40 drops from 40 to 0 (quick increments). When it's cold it still reads really high >150. My TPS is set at .38 idle and 4.54 WOT. The car has 12,000 miles on it. I haven't taken the IAC valve out to inspect yet. Could it be a bad IAC valve? My AF number is 5-6 at idle. Int and BL are at 128. This chip idles in open loop so I'm not sure if that has something to do with my readings.
Any thoughts?
Any thoughts?
