You can use the 200 ohm range. It should be very low (3 or less) between the 2 plugs if you have a good constant connection.
You can also test the 2 pins on each injector, they should be about 16 ohms if they are smaller high impedance injectors, and about 3 ohms if the are low impedance ones.
