Help, several weeks ago my car blew a head gasket, I replaced the head gasket and started the car. After I started the car I noticed that my car is puffing blue smoke out of the oil tube(not oil stick). There is no smoke coming out of the tail pipe. When I rev up the engine the puffing gets worse. I checked engines compression and I noticed that the #1 cylider is only 55 lbs. I checked the rest of the compression and all are between 110-100 lbs. You can actually see and feel the puffs coming out. The spark plugs are not fouled by oil.
The million dollar question is this, Is there a way in which I can be certain if is a bad compression ring or a bad valve? I want to be certain what is it, before I start wondering and start to take the engine apart. ( the engine has approx, 10,000 miles, freshly rebuil).
would appreciate any help, thanks
