I have a pretty straight forward alky kit on my car (made by coolingmist) that is currently set to come on at 10lbs. The pump is a 150psi variation of the sureflow, and I currently have denatured alky in the tank. Not mixed. 100% denatured. Problem I am having is a real bad stumble. It does not happen all the time, but when it does, the car stumbles real bad and just falls on it's face until I get out of it. Other times it will pull real strong and will not stumble. This happens at both WOT and part throttle. I would say, it wont stumble about 40% of the time. The other 60%, its real bad. Not a light stumble....bad to the point where the car begins to buck. Boost levels are not crazy right now. The needle will spike over 20, but settle to a steady 18-19 at WOT. When this occurs, car has an initial surge of power and then just falls flat to where I need to get out of it.
