Jul 31, 2002 #1 B buickruss Active Member Joined May 25, 2001 Messages 877 would a bad turbo cause the car to burn oil at idle or just under boost?
Jul 31, 2002 #3 Mr URL Member Joined May 24, 2001 Messages 678 Pull off the inlet pipe (or hose) and down pipe then take a look.
Aug 12, 2002 #4 B bsdlinux Just Another BLACK Car Joined Jul 29, 2001 Messages 1,540 What did you find out? I have a similiar problem. Only smokes at idle when warmed up. No smoke when going down the road or when you get on it.
Aug 12, 2002 #5 B buickruss Active Member Joined May 25, 2001 Messages 877 I sent the turbo to P.T.E. They said it was bad seals and a scored shaft. This was allowing the oil to blow thru into the intake.
Aug 13, 2002 #6 R REDS HOT AIR Buick Tweaker Joined May 24, 2001 Messages 3,433 Originally posted by buickruss I sent the turbo to P.T.E. They said it was bad seals and a scored shaft. This was allowing the oil to blow thru into the intake. Click to expand... weird since the seal dont touch the shaft...
