baer brakes users
boostx
KEEP ON BOOSTING
those of you who have the front baer brakes what type of rims are you using...
I have 12" baers with BAER modified stock G-body spindles on my '86 Pontiac Grand prix and use GTA 16X8 fronts and 255ZR50's (Pontiac wheel openings are a little bigger)
my reason for asking is i just install 12 BAER system on the my gn and my GTA (fronts ) does ont fit confused: :confused: :confused:
The 12" BAERs should fit with 15" T-type wheels. Where do they rub? If you have stick on wheel weights, I can see where you might get rub on those. That is weird.
there is a slight hump in the rim and the calipers is rubbing on it
