M marred4life Banned Joined Mar 15, 2002 Aug 19, 2006 #1 does anyone know the part number to the baer tracker tie rods, its for the b-body spindle upgrade, to eliminate pumpsteer.
D dwkohout Member Joined Nov 24, 2005 Aug 19, 2006 #2 You can try them but they're not going to help. The ideal location for the outter tierod is the center of the spindle arm. http://www.jegs.com/webapp/wcs/stor...atalogId=10002&storeId=10001&categoryId=58801
M marred4life Banned Joined Mar 15, 2002 Aug 21, 2006 #3 so what do you recommend im running a 16" wheels and the bumpsteer is really bad. i still have the factory 20yr old springs :redface:
D dwkohout Member Joined Nov 24, 2005 Aug 22, 2006 #4 #1 Mod the draglink like I meantioned before. #2 Use the original spindles. LS1 brakes and tall balljoints. #3 Limit suspension travel. Stiff springs and shocks. #4 Alignment. Increase caster it should raise the outer tierod.
