BUT! I did notice the heavy washer that goes on the 1 1/8 bolt fits pretty lose on
the bolt and it look as though it had been spinning on about the last 1/16th-1/8" of the threads and flattened out about four rows of the bolt ie just before
the head of the bolt. Do you know if the wash is suppose to have play in
the balancer or how much play it should have around the bolt.
At first I thought no problem I'll head to the hardware store and buy a new bolt #3 and washer, but I noticed that if you look really close at the bolt it appears that the first half of the threads are shorter in height than the last half ie just prior to the head of the bolt. Is this a special bolt and washer- I realize they are hardened but would these be avaliable at the hardware store?
Has anyone run into this before?
